Bookmark
Subscribe
929
6509 not accept address-family vpnv4
Dears do you known because may Switch 6509 not accept this command
follow some informations
MODEL: cisco WS-C6509-E
SUP: Supervisor Engine 720
IOS: s72033-ipservicesk9_wan-mz.122-33.SXH3.bin
Could be because Model, or SUP, or IOS?
Thanks for all
Giuseppe Larosa
Hello Silvio,
it is a question of IOS version you should need an advanced ip services feature set
for MPLS full features you need a sup720B or better, MPLS is not supported on sup720
Hope to help
Giuseppe
So I need change IOS and SUP?
Hello Silvio,
yes if you have sup720 only you need to change it to support MPLS features and also the IOS image feature set.
if you have sup720B or better you need only to upgrade the IOS image
Hope to help
Giuseppe
Look it seens Series B correct
WS-SUP720-3BX
sh module
5 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL
