Question on Cisco C9300L-48P-4X 48 PoE+
EF_777
Can someone please tell me if C9300L-48P-4X 48 PoE+ switch's fixed 10G up-link ports support 1G sfp's too?
6 Replies 6
Reza Sharifi
That model supports only 4x 10Gig.
according to the hardware installation guide linked below:
--> The C9300L switches provide fixed uplink ports that support 10G and 1G SFP/SFP+ modules.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/b_c9300_hig_chapter_01001.html
Hi Georg,
The data sheet (table-1) has this switch as fixed (C9300L-48P-4X). So, not sure which document is correct :)
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
balaji.bandi
As per my knowledge, it does not support 1GB, it has fixed 10GB.
BB
Are you sure about that? The Transceiver Compatibility Matrix shows support for both 1Gb and 10Gb SFPs on the 10G fixed uplink switches (i.e. C9300L-24P-4X-E). I am going to have my SE check with the BU just to confirm before we buy any.
https://tmgmatrix.cisco.com/?dr=8&dr=10&npf=601
Joseroncal
The 9300L 48P-4x supports 1G SFP Modules: I am using GLC-SX-MMD model to use the uplinks with 1Gb speed
Switch#show interfaces transceiver supported-list
Transceiver Type Cisco p/n min version
supporting DOM
DWDM GBIC ALL
DWDM SFP ALL
RX only WDM GBIC ALL
DWDM XENPAK ALL
DWDM X2 ALL
DWDM XFP ALL
CWDM GBIC NONE
CWDM X2 ALL
CWDM XFP ALL
XENPAK ZR ALL
X2 ZR ALL
XFP ZR ALL
Rx_only_WDM_XENPAK ALL
XENPAK_ER 10-1888-04
X2_ER ALL
XFP_ER ALL
XENPAK_LR 10-1838-04
X2_LR ALL
XFP_LR ALL
XENPAK_LW ALL
X2_LW ALL
XFP_LW NONE
XENPAK SR NONE
X2 SR ALL
XFP SR ALL
XENPAK LX4 NONE
X2 LX4 NONE
XFP LX4 NONE
XENPAK CX4 NONE
X2 CX4 NONE
XFP CX4 NONE
SX GBIC NONE
LX GBIC NONE
ZX GBIC NONE
CWDM_SFP ALL
Rx_only_WDM_SFP NONE
SX_SFP ALL
LX_SFP ALL
ZX_SFP ALL
EX_SFP ALL
SX SFP NONE
LX SFP NONE
ZX SFP NONE
GIgE BX U SFP NONE
GigE BX D SFP ALL
X2 LRM ALL
10GE SR SFP+ ALL
10GE LR SFP+ ALL
10GE LRM SFP+ ALL
10GE ER SFP+ ALL
10GE ZR SFP+ ALL
10GE DWDM SFP+ ALL
10GE TDWDM SFP+ ALL
GIgE BX 40U SFP ALL
GigE BX 40D SFP ALL
GigE BX 40DA SFP ALL
GIgE BX 80U SFP ALL
GigE BX 80D SFP ALL
10GE GIG BXU SFP+ ALL
10GE GIG BXD SFP+ ALL
10GE GIG BX40U SFP+ ALL
10GE GIG BX40D SFP+ ALL
GigE Dual Rate LX SFP ALL
10GE CWDM SFP+ ALL
CPAK_SR10 ALL
CPAK_LR4 ALL
CPAK_ER4L ALL
CPAK_SR4 ALL
QSFP_LR ALL
QSFP_SR ALL
QSFP_ER ALL
SFP28_SR ALL
SFP28_10_25_LR ALL
SFP28_CU NONE
SFP28_AOC NONE
QSFP28_SR4_S ALL
QSFP28_LR4_S ALL
QSFP28_ER4L_S ALL
QSFP_H40G_AOC NONE
QSFP_H40G_ACU NONE
QSFP_H40G_CU NONE
QSFP_40G_ER4 ALL
QSFP_40G_CSR_S ALL
QSFP_40G_CSR4 ALL
QSFP_40G_LR4 ALL
WSP_Q40GLR4L ALL
QSFP_40G_LR4_S_SFP ALL
QSFP_40G_SR_BD NONE
QSFP_40G_SR4_S ALL
