question on: switchport trunk allowed vlan
danny9797
Hi everyone,
I wouldn't mind getting some clarification on this commant.
By default, a trunk carries ALL Vlans.
My basic question is, if I use the "switchport trunk allowed vlan 4" command, will the trunk DROP traffic from every Vlan except 3?
Eg,
interface GigabitEthernet5/34
description cisco
switchport trunk allowed vlan 109
switchport mode trunk
If I configure the above port in this manner, am I only allowing Vlan109 traffic through?
5 Replies 5
cadet alain
yes you only enable vlan 109 out the trunk port.
Regards.
Alain
Hi Alain,
I appreciate the response because I read differently on other documents and websites.  I read the following comman sets would be required in order to just allow Vlan 109 out of the trunked interface:
description cisco
switchport trunk allowed vlan remove 1-108, 110-4094
I assumed the allowed vlan xx command would automatically discard traffic traversing that given interface which does not reside in that specified vlan.
Dan
you are correct once you enter the command it will remove all vlans.  Just remember if you need to add a 2 or 3 make sure you use the add commnad
switchport trunk allowed vlan ADD 110
This would add vlan 110 to the existing vlan 109.
Steve
you don't need to remove the vlan  first.
Regards.
Alain
danny9797
Thank you for the clarification.
