Question regarding ip default-network
s.quirion
Community Member
I am studying route summarization and am having an issue with my remote router automatically marking a route as default. Thanks in advance for any advice! Please advise if you require more settings from either router.
Local Router:
First I created a loopback with the ip 192.31.7.1
Second I added it to my EIGRP AS
Third I added the command: ip default-network 192.31.7.0
As you can see, my loopback IP is marked as exterior
sho ip eigrp top 192.31.7.0 255.255.255.0:
IP-EIGRP (AS 1): Topology entry for 192.31.7.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 128256
Routing Descriptor Blocks:
0.0.0.0 (Loopback8), from Connected, Send flag is 0x0
Composite metric is (128256/0), Route is Internal
Vector metric:
Minimum bandwidth is 10000000 Kbit
Total delay is 5000 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1514
Hop count is 0
Exterior flag is set
Remote router:
show ip route:
Gateway of last resort is not set
172.16.0.0/24 is subnetted, 5 subnets
D       172.16.104.0 [90/156160] via 10.0.0.1, 00:10:20, FastEthernet4
D       172.16.105.0 [90/156160] via 10.0.0.1, 00:10:20, FastEthernet4
D       172.16.106.0 [90/156160] via 10.0.0.1, 00:10:20, FastEthernet4
D       172.16.102.0 [90/156160] via 10.0.0.1, 00:10:20, FastEthernet4
D       172.16.103.0 [90/156160] via 10.0.0.1, 00:10:20, FastEthernet4
10.0.0.0/30 is subnetted, 1 subnets
C       10.0.0.0 is directly connected, FastEthernet4
D    192.31.7.0/24 [90/156160] via 10.0.0.1, 00:10:20, FastEthernet4
D    192.168.2.0/24 [90/30720] via 10.0.0.1, 00:10:20, FastEthernet4
D    192.168.100.0/24 [90/28416] via 10.0.0.1, 00:10:20, FastEthernet4
The second router HAS learned the route via EIGRP. Am I incorrect in thinking that when the router that is advertising the default network does so, the remote router should automatically mark this route as default? As you can see there is no asterisk next to any route. Of course if I add the ip default-network command to the second router as well, it then sets the gateway of last resort. But shouldn't this happen automatically?
Thanks very much!
Steve
Peter Paluch
Hello Steve,
I have observed a similar behavior myself when experimenting with the ip default-network command on 15.x IOSes. While the EIGRP-learned route had the Exterior flag set, it was not marked as candidate default in the router's routing table. This is exactly what you observe here. Are you perhaps running some 15.x IOS here?
To be honest, I have never found a solution to this. In my personal experience, this is either a bug, or Cisco is silently dropping the support for ip default-network command that is itself an unfortunate remainder of past IGRP and has a number of shortcomings. Whenever I was able to, I discouraged people from using the ip default-network command - but I understand your desire to learn about its behavior so this is not the kind of advice I should be giving to you Unfortunately, I cannot give you any other advice, either. The recent IOSes simply seem to take the external flag on EIGRP-learned routes into account.
Best regards,
Peter
Peter Paluch
Hello Steve,
Best regards,
Peter
Peter,
Thanks so much for your reply. It's nice to know I had the config correct, and it was an issue of out my hands.
In regards to my IOS I am not running:
Local:    C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(37)SE
Remote: C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T7
So not 15.x, but I am not terribly concerned with getting it to work as its just my lab. However for future reference, in your opinion, what is the best way to accomplish the task of telling other routers about default routes, without using the ip default-network command?
Thanks again,
Steve
Hi Steve,
You could have a look at using the default-information in EIGRP-level command that should control which neighbors will EIGRP accept the default networks from. Still, the default setting of this command should be that there are no limitations on which neighbors are allowed to send us the default routing information.
The best way in my opinion is to redistribute a default route 0.0.0.0/0 into EIGRP. The default route 0.0.0.0/0 is so or so the only universal way of having a gateway of last resort propagated through any routing protocol, be it RIP, EIGRP, OSPF, IS-IS or BGP. The concept of "default network" was originally invented for IGRP that was, by design, unable to carry the 0.0.0.0/0 network. However, IGRP is not supported anymore, and the 0.0.0.0/0 route is universally recognized.
Injecting a default route into EIGRP can either be done by redistributing it from a different source (a static route, for example), or in selected topologies, you may use the ip summary-address eigrp command to summarize all advertised routes into a 0.0.0.0/0 network.
Best regards,
Peter
