Questions on 3650 Stack and Power Options.
sanjaynadarajah
I have the following two questions around the working of the 3650s.
i) Can a 3650 be stacked with different 3650 models ? ie) a WS-C3650-24PD-E (PoE) and a WS-C3650-24TD-S (non-PoE).
    My understanding is that this is allowed as long as the image on both these switches are the same but need this to be confirmed.
ii) With regards to having a redundant power supply on the 3650, does it only run on redundant mode ?  I can't find the command
   to verify it runs on redundant/combined.
Thank you.
Cheers,
SN
Philip D'Ath
Whenever I have priced it up, as soon as you want to start doing stacking the 3850's become attractive price wise.  So please consider the 3850's as an option as well.  Also note the 3850's support power stacking, as well as data stacking.  Specifically the power supply from one 3850 can be used to feed power into another 3850.  Depending on the power budget, sometimes you don't need to do anything extra for power redundancy than plug in the power stacking cables.  Hence saving in the cost of buying extra redundant power supplies.
You can stack switches from the same family as long as they have the same licence (e,g. IP Base, Enterprise, etc).
I don't know for the 3650 - but I would expect it to only run in redundant mode.  I don't see the point otherwise.  Because the 3850's can do load sharing between the chassis members you have all sorts of options with the 3850's.
Cisco 3850's even support load shedding.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/int_hw_components/configuration_guide/b_int_3se_3850_cg/b_int_3se_3850_cg_chapter_01000.html#con_1013434
Philip D'Ath
Yes you can do it, (i did the same last low weeks)
ii) no idea
Well when I used the Cisco Power Calculator, it seems that it can run in redundant and combined mode. The FAQ on the 3650 says this as well.  (Please refer to the attachment)
The issue is that I can't find the command to configure this on the switch. Can anyone let me know as to how to configure this ?
Many thanks.
Cheers,
SN
hi, I am looking for the same. did u get the ans?
