Quick Question - Easy
visitor68
Level 5
Level 5
I need a fixed configuration data center switch (Catalyst is fine) that offers more than 24 ports of 1G SFP, not RJ-45. Need SFP fiber interfaces...
Which data center switches offer more than 24?
dominic.caron
Level 5
Level 5
You have the 4900M if you use network modules and twingig adapters.
You can also go with a nexus 5548
and the 4500X
I would go with the a 5548 or a 5596, the 4900M is...pricy.
Here are the Datasheet of Nexus family:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/data_sheet_c78-618603.pdf
Like dominic says: Nexus 5548/5596  with Nexus 2000 on Top of the rack design; but it is preferable that you study carefully what are you need before make a decision.
In my opinion, Nexus family is the future because are designed for DataCenter, it is a new concept of DataCenter: "Converged DataCenter".
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/qa_c67-618605_ps9670_Products_Q_and_A_Item.html
Regards.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/C07-572831-00_Dsgn_Nexus_vPC_DG.pdf
Hi visitor68,
Did it helped you?
Regards.
