Quick question on connecting to ip address
Bagley5777
Hello and thanks for your help on this.  Just need to know why the answer would be "d" IP address is incorrect.  Why not the default gateway is incorrect?  Since the computer is on another network they are trying to hit, I thought it would be the gateway...
A user cannot connect to the 192.168.1.0 network. Review the ipconfig results that follow
and select the best answer to explain why this has occurred.
Windows IP Configuration
Host Name . . . . . . . . . . . . . . . . . . . . . . : Computer1
Primary Dns Suffix . . . . . . . . . . . . . . . . . :
Node Type. . . . . . . . . . . . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . . . . . . . . . . : No
WINS Proxy Enabled . . . . . . . . . . . . . . . . : No
Ethernet adapter LAN:
Connection-specific DNS Suffix.:
Description . . . . . . . . . . . . . . . . . . . . . . : Intel(R)
82566DC-2 Gigabit Network Connection
Physical Address . . . . . . . . . . . . . . . . . . : 00-1C-C0-A1-55-16
DHCP Enabled . . . . . . . . . . . . . . . . . . . . : No
Autoconfiguration Enabled . . . . . . . . . . . : Yes
IPv4 Address . . . . . . . . . . . . . . . . . . . . . : 10.254.254.105(Preferred)
Subnet Mask . . . . . . . . . . . . . . . . . . . . . : 255.255.255.0
Default Gateway. . . . . . . . . . . . . . . . . . . : 10.254.254.1
DNS Servers . . . . . . . . . . . . . . . . . . . . . . : 10.255.254.1
a. The MAC address is incorrect.
b. The DNS server address is incorrect.
c. The default gateway address is incorrect.
d. The IP address is incorrect.
Richard Burts
I agree with you. I do not see anything in what was presented that would indicate that the address was wrong and that a likely cause of the issue would be wrong default gateway.
Rick
Rick
Deepak Kumar
I agree that May be Gateway is also wrong. But maybe examiner was thinking that he didn't mention anything about VLAN or VLAN routing or routing. So the student should be understood that my both systems are on the same network. So he/she marked answer D is correct.
But If you are a technical guy then there are many points where maybe he is wrong.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
