routing between vrf
jwilde
Level 3
Level 3
I have a situation where i have a default vrf and a Video vrf.  Is there a way without BGP to route between the two.  The reason being is my Video needs to get an ip from a dhcp server on the default and all the multicast is originating from the default as well.  I've been trying to figure it out, but it seems like it can't happen which i would understand.
jdw
jwilde
Level 3
Level 3
this is on ios-xr i forgot to add that.
jdw
Julio E. Moisa
Have you tried importing the route-targe on each other VRF or using mapping to leak specific networks?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
can you give me an example? i haven't found anything that supports that but that was my goal.
jdw
For example:
ip vrf A
rd 1:1
route-target export 1:1
route-target import 1:1
route-target import 2:2
ip vrf B
rd 2:2
route-target export 2:2
Other way could be, (im a little bit rusty but I will test it later)
access-list 10 permit x.x.x.x <wildcard>   ---> Host or subnet to be leaked into the other VRF.
route-map LEAKING permit 5
match ip address 10
set extcommunity rt <route-target> additive   --> the route target should be the other VRF route target.
ip vrf A
rd 1:1
export map LEAKING
