"NAT %Port <> is being used by system" on cisco ISR4331
mamaral
Hi!
I'm having a problem with an ISR4331 regarding NAT.
I cannot make a static nat for port 5011 because it keeps reponding this:
%Port 5011 is being used by system
The show ip socket gives me this:
Proto Remote Port Local Port In Out Stat TTY OutputIF
17 255.255.255.255 68 192.168.1.254 67 0 0 2002211 0
17 10.16.214.7 514 192.168.1.254 64191 0 0 400210 0
And the show ip nat portblock dynamic global gives me this:
tcp:
8192 -9215 7168 -8191 6144 -7167 5120 -6143 4096 -5119
545 -617
udp:
8597 -9620 7573 -8596 6549 -7572 5525 -6548 4501 -5524
585 -648 512 -584
So, why can't i use the port 5011 ????
The ios is: 154-3.S5
Tkx
Miguel
18 Replies 18
What IOS-XE version are you using?
It's running:
Cisco IOS XE Software, Version 03.16.01a.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5 (3)S1a, RELEASE SOFTWARE (fc1)
nidaye
This is a bug.
My device is 4300 ,IOS Version is 15.5(3)S4b.
command is :
int g0/0/0
no ip add
than you can nat the port
I tested it.
Then configure the IP G0/0/0
You have to remove the ip address from the interface first before you can add your static nat.
Tested
