"pause input" on C10K connecting to Cat4507R
limtohsoon
Hi Sir,
A Catalyst 4507R is directly connected to a Cisco 10008's interface Gi1/1/0. "sh int gi1/1/0" on the C10K is as follows:
GigabitEthernet1/1/0 is up, line protocol is up
Hardware is Half-height Gigabit Ethernet MAC Controller, address is 001d.a269.8d24 (bia 001d.a269.8d24)
Description: *** Connection to Catalyst 4507R ***
Internet address is 2.1.1.67/27
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 87/255, rxload 16/255
Keepalive set (10 sec)
Full Duplex, 1000Mbps, 1000BaseSX, Auto-negotiation, media type is SX
output flow-control is XOFF, input flow-control is XOFF
Last input 00:00:05, output 00:00:00, output hang never
Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
Interface GigabitEthernet1/1/0 queueing strategy: PXF Class-based
5 minute input rate 65216000 bits/sec, 44622 packets/sec
5 minute output rate 344833000 bits/sec, 47251 packets/sec
13753696 packets input, 827763454 bytes, 0 no buffer
Received 1240021 broadcasts (0 IP multicasts)
0 watchdog, 1240015 multicast, 241410137 pause input
1510948108 packets output, 3359148857 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
I notice a high number of "pause input". Please advise what to configure on the Cat4507R's port to reduce this.
Thank you.
B.Rgds,
Lim TS
Ryan Carretta
Try turning off flowcontrol on the 4k interface.
Hi Ryan,
Below is "sh int" on 4507R's interface connecting to the C10K:
GigabitEthernet3/6 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 0017.958b.bf2b (bia 0017.958b.bf2b)
Description: *** Connection to Cisco 10008 Gi1/1/0 ***
reliability 255/255, txload 17/255, rxload 87/255
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX
input flow-control is on, output flow-control is on
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 341837000 bits/sec, 46722 packets/sec
5 minute output rate 67001000 bits/sec, 44361 packets/sec
220485800313 packets input, 186924487300379 bytes, 0 no buffer
Received 611093 broadcasts (611087 multicasts)
77 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
193263552385 packets output, 36812566451171 bytes, 0 underruns
By disabling flow control, will it cause input error counters to increase?
Thank you.
B.Rgds,
Lim TS
It certainly could - it depends how much traffic you're pushing. The 4k is trying to flowcontrol the neighboring device for a reason. :) If you do see input errors, that may be an indication you're pushing too much traffic over this interface.
