Rack Mounting a 4900M switch into a 32 inch 4post rack
kcobb
All,
I would appreciate any ideas on where I can buy specialty hardware to install a 4900M into a 32 inch rack.
The customer does not feel comfortable just front mounting it and the supplied rack mounting kit only extends 28 inches.
The customer also does not want to move the rear posts in the rack up a few inches because of other devices in the rack.
Thanks again.
Kevin Cobb
Edison Ortiz
Kevin,
Any local vendor should be able to provide you a shelf for that rack.
Slide the 4900M in the shelf and secure it with the front mounting sleeves, if needed.
HTH,
__
Edison.
