Bookmark
Subscribe
3163
Cisco and HP switch compatibility
BilalButt62333
Dear Kindly let me know if cisco switch and HP switch can be connected through trunk port whether it is gigaethernet or 10 G sfp port trunk , specifically Cisco 3560X with J8693A or is there any issues in compatibility ?
balaji.bandi
Technically they should work as expected and most of the industry using them already - I have configured a connection between Cisco and HP, spec model I may not have a working HP side, but that should work, as long both side have same Optics used ( Like Single-mode or Multimode) - you can not mix it
config reference :
https://www.petenetlive.com/KB/Article/0000741
https://techexpert.tips/hp-switch/trunk-between-hp-switch-and-cisco-switch/
BB
balaji.bandi
config reference :
BB
b_harvey92
Yes the two switches do inter operate together. I’ve configured a L2 trunk between both vendors in the past. HP are decent switches and much cheaper than the other top vendors.
Hello
Yes they can be connected together, be it 1gb/10gb as long as the SFP's are compatiable to the switches you insert them in
Kind Regards
Paul
