rate limit trunk port on 3750
lkadlik
Is it possible to rate limit on a L2 trunk port on a 3750?
current port config and ios are as follows;
interface GigabitEthernet1/0/50
description ***  Connection to Fiber Link  ***
switchport trunk allowed vlan 1,172
switchport mode trunk
end
flash:c3750-advipservicesk9-mz.122-46.SE.bin
i was wondering if the "srr-queue bandwidth limit 10" command would work to limit the output from this interface to be 10 % of the port bandwidth and then the same command could be done on the other side.
If so, is there anything else that I would need to do?  If not, thoughts?
thanks
Giuseppe Larosa
Hello Ikadlik,
Yes it should work
Hope to help
Giuseppe
