Rate Limiting
viraj.ghoparkar1
Community Member
is it possible to limit bandwidth to selected ip list on router ??
i have total 50 ip from which i want 30 ip get bandwidth of 4mbps and rest of ip get 10mb of up/down stream.
Thanks in advance.
soulasmarios
You can use policing or shaping for outbound and shaping Inbound direction based on the traffic inspection using NBAR.
Note: NBAP can cause CPU issues.
Joseph W. Doherty
If the router supports CBWFQ, the answer is likely yes (for fifty IPs). (BTW, you don't need NBAR for this.)
