10-16-2019 02:57 PM
I am planning on rebooting both the supervisor sup2T modules in our 6509E core switch. I want to do this with little to no downtime. My supervisor modules are running 15.1(2)SY2 software on both. the redundancy are configured to use SSO. What command should I use, and in what order should I reboot them? I realize this is a bit of a newbie question but given that this is the core of our entire campus network, I would like to get this right with as little interruption to the users of our network (specifically our students) as possible.
Thank you all for your assistance in this.
10-16-2019 03:40 PM
10-17-2019 06:53 AM
10-17-2019 01:08 PM
You can use "redundancy reload peer" which only reboots the second sup.
Than after rebooting the second sup, you can switch over to the second sup and now the same for the other sup.
10-17-2019 01:55 PM
