Receiving "inconsistent TLB values" error when trying to add vlan
alwhitlow
Have CAT2950s, 3550s, & 3560s that have converted from VTP client mode to transparent mode & used config mode instead of vlan database to make the changes.
Now, am unable to add vlan using config mode nor vlan database and am rx the following error:
"VLAN 1002 TLB 1 VLAN 1 has inconsistent TLB values (0 / 0)"
Sample of vlan config looks as follows:
vtp domain BergerNet
vtp mode transparent
vlan 175
name VOIP-Elink(234.32/29)
vlan 200
name test
vlan 202
name DDNS_TEST_NET
vlan 1002
tb-vlan1 1
tb-vlan2 1003
vlan 1003
tb-vlan1 1
tb-vlan2 1002
parent 1005
vlan 1004
bridge 1
stp type ibm
vlan 1005
bridge 1
Any ideas on what is creating this problem and how to correct?
Thanks in advance for assistance in this matter!
smalkeric
Level 6
Level 6
It looks like bug to me, Check the bug-id: CSCdv31841
Try this:
Remove translations to vlan 1 from vlans 1002 and 1003, as follows in this
example:
switch# vlan data
switch(vlan)#no vlan 1002 tb-vlan1 tb-vlan2
switch(vlan)#no vlan 1003 tb-vlan1 tb-vlan2
switch(vlan)#apply
I know this post is old but I had the same issue.
if you try to do each vlan individually you will get that "xxxx has inconsistent TLB values"
I quickly resolved it by doing the following.
#conf t
(config)#vlan 1,1002,1003 (the vlans tagged with the tb-vlan #)
(config-vlan)#no tb-vlan1 1 (your no statements)
this will clear those commands on multiple vlans you specify.
