Recovering a 3750 switch
flash2200
Hi all,
Working on recovering a 3750 switch...
Flash file system was formatted and then I copied the IOS bin file. No other files are on the flash file system. When the switch is reset if loads the IOS image and appears to successfully complete the POST and then ends off with the test below before "hanging" with a blinking cursor.
Top Assembly Part Number : 800-21980-01
Top Assembly Revision Number : F0
Version ID : N/A
Hardware Board Revision Number : 0x0B
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750-48P 12.2(37)SE C3750-IPSERVICESK9-M
Now there is no config.text file on this switch but I assumed this would be detected and I would be prompted to walk through the routine first time setup interview to get a basic config going but it just hangs...
Am I missing something?
TIA
royalblues
Level 10
Level 10
Try uploading the IOS again through Xmodem and check
Narayan
smothuku
Level 7
Level 7
Hi ,
follow the below procedure to load the IOS using xmodem.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
satish
