Redirecting to FTP using double pipe
kmart1287
It is possible to redirect a show command output to FTP "show inventory | redirect ftp:".
but the problem I am running into is including a double pipe "show inventory | i xyz | redirect ftp:".
it doesn't work
The problem is I cant get the double pipe to redirect to FTP, instead it just shows the output on the switch instead of redirecting to FTP
show inventory | i 10G | redirect ftp**://**
NAME: "Switch 1 FRU Uplink Module 1", DESCR: "2x1G 2x10G Uplink Module"
PID:, VID: , SN:
Switch model 3850 48port / IOS 16.6.8
Any help is appreciated.
balaji.bandi
That is limitation you can redirect to FTP and sort there with script for 10G
BB
