Showing results forĀ
Search instead forĀ
Did you mean:Ā
Configuring a Cisco SG350 52p to have voice and data on the same port
lk052
I've configured 2960x & 3850 switches but I'm with a newer company that has the SG350 Gui interface. I've enabled ssh but of course the previous commands I've used aren't working since it appears not to have the catalyst OS so most commands I've previously used aren't working. I need to configure  each port to handle data & voice without causing any conflicts. I know
I need to assign vlan’s then assign specific ports to the vlan. Make the port a trunk port so it can have multiple vlans. But I need help with the right configuration so that if I'm assuming I need multicasting on each port. I prefer using putty but will take help with the GUI also.
Thank you
balaji.bandi
disable smartport config global and follow below thread :
https://community.cisco.com/t5/small-business-switches/sg350-28p-voice-and-data-vlan-config-on-a-single-port/td-p/4008018
BB
