Reduce 802.1x Interface template
Aamir Bhatti
Community Member
Hello All,
We recently adopted Dot1x with IBNS 1.0 on out access switches. For management and better control we want to reduce the commands on the ports. We cannot use templates/macros as below commands are not supported by it. We also cannot use aaa policy as we dont have advance license. Do anyone have any idea here?
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication control-direction in
authentication event fail action next-method
authentication event server dead action authorize voice
authentication event server alive action reinitialize
authentication periodic
authentication timer reauthenticate server
authentication timer inactivity server dynamic
Hi, what is the exact platform and software version you are talking about?
Hi @Jens Albrecht, we are using mostly 9000 series(CAT9K_LITE_IOSXE, Version 17.9.5) and some C2960X Software (C2960X-UNIVERSALK9-M) switches.
So this is a question about switch port configuration, not wireless, so I'll move it to the switching board.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
