Redundancy Test Scenarios and Measurement Tools
ergonullu
Hello All,
We have big networks with Cores (HSRP and VSS),Dists etc.
I would like to ask how do measure your redundancy ? With Ping ?
For example when you shutdown your Core 1  what do you check ? and How ?
My issue is from network point of vie my network is redundant but from perspective of customer redundancy recovery times are slow....
Thanks for support
Rgs
balaji.bandi
Follow This GUIDE
it has failover scenarios and testings.
make sure device are dual homed all your distribution/Access switch.
orphan ports (or single connected end points to Core will not work).
BB
