Creating switch stack using different switches and IOSes
Hi All,
I would really appreciate if someone can help me on clearing the doubts that I have about Cisco Stack Wise.
01. Is it necessary to have same IOS version running in all the stack members in order to create a stack? If not what are the limitations that are there when using different IOS versions?
02. Can we create a single stack using Catalyst 3750x switches and Catalyst 3850x switches?
Thank you and Regards,
Gayansa
Hope we answered your queries, if all is good, can we mark it as resolved.
BB
5 Replies 5
balaji.bandi
BB - if i recall old days with Cisco 3750 switches you can have IP Service and IP base IOS version in the stack. but that is changed in new model i guess, you need to have same version when it come to new IOS XE.
BB - you can not mix the model to stack (in the same family you can do like 3750 with 3750 - (some model not spport need to look documenation)
BB
Joseph W. Doherty
"01. Is it necessary to have same IOS version running in all the stack members in order to create a stack? If not what are the limitations that are there when using different IOS versions?"
For the 3850 switches, I believe the answer is same version and feature license.
For the 3750 switches, unsure if same applies to 3750X series, but the original 3750 series, and the -E series too (?), could mix feature sets, and even IOS versions, but when mixing IOS versions, the "major" StackWise version has to match, but "minor" StackWise versions didn't have to match.  Generally, sure bet was to use the same IOS version within a stack, but I dealt with mixed feature set 3750 stacks w/o issue.
"02. Can we create a single stack using Catalyst 3750x switches and Catalyst 3850x switches?"
To my knowledge, no.  You can mix models with the same family.  For the 3750s, you could also even mix the original models with the -E and X 3750 series, but that also caused the later two series StackWise+ to run in StackWise mode.  Also, with the 3750G-12S, it had SDM templates unique to that model (designed, and with resources, for a distribution role), i.e. only to be used in a stack with like models, but it also supported the "normal" SDM templates if you were going to use that model with other 3750 switches (in the stack).
Leo Laohoo
For IOS-XE:
  • Must be the same version
  • Install Mode OR Bundle Mode (not both)
  • Same License level
What will happen if stack members do not follow the above "rules"?  Simple, the switch members will NOT join the stack.
Not remotely possible.  The stacking cables have different physical shapes and the OS are different (classic IOS vs IOS-XE).
3850 does not support "Switch Clustering".
Hi All,
Thanks a lot for all your replies, really was helpfull.
Thank you,
Gayan
BB
