regarding SVI's
hi.622823
What is the difference between an SVI and a routed port?
10 Replies 10
Kevin Dorrell
Level 10
Level 10
An SVI is an interface that represents the gateway for a VLAN, in other words it is the router interface for a set of switchports on a VLAN.
A routed port is a physical interface that you have declared as no switchport. You are treating like the Ethernet interface of a router. It is essentially a point-to-point link to another router or to a routed port in another switch.
Kevin Dorrell
Luxembourg
Edison Ortiz
A routed port is configuring an IP address under a switchport. This connection is considered point-to-point.
SwitchA
interface f0/0
no switchport
ip address 192.168.1.1 255.255.255.252
SwitchB
interface f0/0
no switchport
ip address 192.168.1.2 255.255.255.252
______________________
A SVI is a logical interface that represents a Vlan. This connection is accessible to all members on that Vlan holding a common IP subnet.
interface vlan 192
then you can have workstations with ip subnet 192.168.1.0/24 on the following ports
interface f0/0
switchport mode access
switchport access vlan 192
interface f0/1
interface f0/2
etc...
hi.622823
Wow, fast responses...
I do have one follow up question though, which relates to why I posted this question.
What is the difference between routing in the context of an L3 switch and a router (or routed port)? Let's assume the switch and router are running CEF.
Sorry, I don't understand the question.
Ok, does it make sense to say an L3 switch does routing ie route table lookups?
yes.
Alrighty. What I was trying to get at is how is that functionality different from a traditional router (or is there something I'm missing)?
The functionality is the same from a traditional router. Many organizations have replaced traditional routers with Layer3 switches since they provide higher port density in addition to full routing services.
hi.622823
Great.
Thanks again everyone for your timely responses (especially Edison).
This is exactly the sort of thing that encourages quality participatiion in the Cisco forums.
prabhdeepnijjar
to clear your confusion for the difference between L3 swith and router.Th L3 switch works using the hardware i.e the routing in them is hardware based and it is more fast .While the routers are software based .i.e they make decisions using the software which is much slower than the hardware based switching.
