Remove 3850 Switch from Stackwise Virtual
himanshudwivedi
Level 3
Level 3
I am using two 3850 switches which are stacked together using Stackwise Virtual Link. I want to break the stack and want to use as a standalone switch,, can anyone tell me how to break the stack...
2 Accepted Solutions
Reza Sharifi
The "no stackwise-virtual" command will convert them to stand-alone mode. You most likely have to reboot after converting them
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-3/command_reference/b_163_consolidated_3850_cr/b_163_consolidated_3850_cr_chapter_011100.pdf
Reza Sharifi
