Remove macro from interface
AvdVyver
Level 3
Level 3
Hi all,
I was busy preparing previously unused ports on the my SG550XG when I noticed that one of the ports (te1/0/10) contains some macro config. I don't use macros and I also don't use voice on this switch. I tried to remove config but the below is what I ended up with:
csw1#sh run int te1/0/10
interface TengigabitEthernet1/0/10
 macro description no_switch
 no macro auto smartport
How can I clear this configuration?
Using the UI, the Smartport section indicates "Administrative Auto Smartport" is set to "Enabled by Auto Voice VLAN".
And when navigating to the "Voice VLAN" properties, it states that the Voice VLAN ID is set to 1. Would this in any way affect the native VLAN?
Can I safely disable the "Administrative Auto Smartport" and "Voice VLAN" without affecting the current switch operations?
Thank you
AvdVyver
Level 3
Level 3
Disabled dynamic voice VLAN
Disabled administrative auto smartport
conf t
no macro description no_switch
Cleared the macro settings
AvdVyver
Level 3
Level 3
conf t
