Removing Oversubscription in cisco 6500
Hasrat Raja
6816 card is configured for performance, need to remove it, will adding command: hw-module slot 2 oversubscription, cause any issue with active ports on the card or any other disruption as this is an operational switch
balaji.bandi
suggest to read full information before you applying the command : make sure you do this in change window or maintenance window - check the IOS version supported features
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/interface/command/ir-cr-book/ir-f1.html#wp3617792678
BB
Leo Laohoo
The entire line card will reboot.
Hi Leo,
Is there a document which tells module will reboot ?
thanks
Couldn't find one but it happened to me once.
