04-28-2022 02:55 AM
I try to remove a policy-map I don't need anymore.
But I get an error message
switch(config)#no policy-map type control subscriber MONITOR_MODE_MAB_POLICY
%policy-map "MONITOR_MODE_MAB_POLICY" currently associated with at least one interface or template. Remove from interface(s) or template(s) first
The switch shows me a binding
switch#show policy-map type control subscriber binding MONITOR_MODE_MAB_POLICY
Policy Name Bound To Interface(s)
MONITOR_MODE_MAB_POLICY Gi7/3
But the interface has no binding configured
switch#sh run int Gi7/3
Building configuration...
Current configuration : 247 bytes
interface GigabitEthernet7/3
switchport access vlan 106
switchport mode access
switchport nonegotiate
no cdp tlv app
channel-group 52 mode active
ip dhcp snooping limit rate 20
end
neither the port-channel
switch#show running-config int port-channel 52
Current configuration : 120 bytes
interface Port-channel52
switchport
end
I have this problem only on interfaces that are member of a port-channel.
Any ideas, how to remove this policy-map?
Stefan
Solved! Go to Solution.
04-29-2022 12:20 AM
Hello
Scheduled a change window and either try shutting down the interface and PC or reload the switch.
04-28-2022 03:24 AM
Looks like something got stuck on the switch. I´d put the interface in default, shut it dow and try to remove the Policy.
Just an attempt.
04-28-2022 03:36 AM
Hello Flavio,
thanks for your hint. I forgot to say, that I tried this already. But no luck.
Maybe it's not so important to remove an unnecessary policy-map, but I wanted to clean up my configs.
Stefan
04-28-2022 03:49 AM
And did you try with the PO as well? I mean, deleting PO, trying to remove the policy. Maybe reloading between procedures.
04-28-2022 03:38 PM
what is the device model, and what IOS Code running?
Do you have an ISE environment ? post-show run full config.
=====️ Preenayamo Vasudevam ️=====
04-29-2022 12:04 AM
Unfortunately, deleting the port channel as well as rebooting the switch is not possible.
04-29-2022 12:06 AM
The switch is
WS-C4510R+E
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9-M), Version 03.11.04.E RELEASE SOFTWARE (fc2)
04-29-2022 12:20 AM
Hello
10-21-2025 02:17 AM
(conf t)#no access-session monitor
