replacement for cisco 2621 router
ogundaretaiwo
please wich cisco router is the best replacement for a cisco 2621 router
7 Replies 7
Mark Malone
The 2921 would be the newer version of that model
Thanks, but does the 2921 have proxy features /Internet Bandwidth Management.
Yes it supports those features you will ned a license for these devices, here is a couple of links that cover the 2921 and has links to the other 2900 series routers and then an overall link for the series which contains what there capable of if that helps
http://www.cisco.com/c/en/us/products/routers/2921-integrated-services-router-isr/index.html
www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/data_sheet_c78_553896.html
It very much depends what you are doing with your 2621.
  1. If you only use the build-in FE-ports and you are only using basic features and need a router that is still supported: The Cisco 881 is one of the cheapest router that could be a replacement.
  2. If you are using a WAN-interface, one of the other 88x could match your needs.
  3. If you need many features and also want to have a rackmount-device, then the Cisco 2901 could be a perfect fit.
  4. And if you want investment-protection and buy a router that will be probably supported for the longest time, then the 4321 or 4331 could be the right device.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Depends what you mean by "best" replacement.
You need to define your performance, feature, interface requirements.
In a later post, you mention "proxy features /Internet Bandwidth Management", but exactly what do these features mean to you?
Moin Ilyas
Level 4
Level 4
The Cisco 2610, 2611, 2620, 2621, 2650 and 2651 routers are being replaced by the Cisco 2600XM routers.
For more details, End-of-Sale Announcement for the Cisco 2600
Sorry, this forum is not Comedy Central ... The original poster probably prefers serious replies!
