SBS SLM2024PT-AU switch port issues
S N
Recently I bought Small business switch SLM2024PT-AU and when I connect all the ports to the switch and the devices like my laptop , printer etc to my network points, only one port is recognizing 1 GB and all other ports are showing as 100MBps.
If I connect my laptop directly to the switch it is showing as 1 GB ( on all the ports).
Let me know if any configuration needs to be done on switch and any other options to be check.
Sathya
Mark Malone
Not familiar with this model but the sg200 which i would say is generally close you can edit port settings, you should be able to set the port to speed 1000 / duplex full try hardcode it see if it makes a difference, on the sg you can also tell it to only negotiate to 100 so make sure its not the same on this switch and its set wrong
