05-10-2011 11:23 AM - edited 03-06-2019 04:59 PM
I have a Cisco 3640 with a NM-16AM module and would like to know if there is something new out there that I can migrate too.
We basically have some Verifione VX570 devices using POTs lines dial into the router and then the router connects these devices to a server through the ethernet network.
Here is the config:
TSB-CON-TRU-001#sho run
Building configuration..
Current configuration : 2407 bytes
! No configuration change since last restart
version 12.2
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname TSB-CON-TRU-001
boot system flash:c3640-i-mz.122-31.bin
logging buffered 4096 debugging
username user password ***omit****
clock timezone PDT -8
clock summer-time PDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
modem country microcom_hdms usa
ip subnet-zero
no ip domain-lookup
ip address-pool local
chat-script clientserver TIMEOUT 30 CLIENT CLIENTSERVER
modemcap entry microcom:FD=&F:DTR=&D2:SPD=$B14400:DTE=14400:BER=\N3:BCP=%C0:MSC=\J0
interface Ethernet2/0
bandwidth 100
ip address 192.168.45.2 255.255.255.0 secondary
ip address 172.16.5.21 255.255.255.0
full-duplex
interface Group-Async1
no ip address
encapsulation ppp
no peer default ip address
group-range 1 15
interface Group-Async2
ip unnumbered Ethernet2/0
ip directed-broadcast
encapsulation ppp
async mode interactive
peer default ip address pool DIALIN
ppp authentication pap
group-range 16 16
interface Group-Async3
no ip address
encapsulation ppp
group-range 33 48
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.5.132
no ip http server
logging history informational
logging trap debugging
snmp-server enable traps tty
line con 0
line 1 15
no activation-character
modem Dialin
modem autoconfigure type microcom
autocommand connect 172.16.5.75 5060 /stream
transport input all
escape-character NONE
stopbits 1
flowcontrol hardware
line aux 0
line vty 0 4
exec-timeout 0 0
password ***omit***
login
end
I had a Vendor tell me that the Cisco SPA8800 can do the same.
05-15-2011 09:13 PM
please read this document I think that is usefull for you
www.cisco.com/en/US/docs/ios/.../dia_nm8amv2_nm16amv2.pdf
thx
MA
05-16-2011 09:00 AM
Thanks for the reply. Isn't the nm-16am-v2 module EOL as well. Does Cisco have anything else?
Thanks again.
05-15-2011 09:26 PM
Out of curiosity, what are you using this setup for?
