Replacing dead Catalyst 6509 switch in VSS
UzzDuzz
Hi there,
I have Core Switches Stacked (VirtualSwitchingSystem) in office's server room. Recently one switch failed due to hardware issue (Cisco Catalyst 6509) with the chassis. I have received the new switch for replacement (same model), wanted to ask, if anyone has experience in replacing a dead core switch within the stack, are there any pre prep before connecting the new switch within the stack or should i just plug it into the stack and the new switch will receive the config automatically?
Uzz
Deepak Kumar
Here is the guide which will help you for the same:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4500-series-switches/117640-configure-vss-00.html
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Deepak Kumar,
Hi, thanks so much, the guide was a great help
Cheers,
Uzz
