SVI Stopped working but Traffic is passing C2950
Mike202
Description:
SVI stopped working in many switches of my inside network but some switches are still working fine. There is a difference of days and hours from 1 switch to other switche when SVI stopped. I tired all the possible solutions from blogs/google and from my own knowledge and nothing worked at all. This network was working fine from many years and no new changes in it.
Troubleshooting done:
  • clear arp & mac addresses
  • create new vlan interface
  • assign new ip address
  • debug ip packets of switch shows encapsulation failed when ping to gateway
  • Switchport mode changed and tried
  • remove all overhead configurations and only vlan 1 is configured in all switches
  • pull out the switch which has non-working SVI and connect it to another fresh router
Solution:
  • A hard reboot to the switch bring the SVI up and all back to normal for 4 to 6 days max and again SVI stopped.
Attached:
configs and vlan info
7 Replies 7
Mark Malone
are these switches running same IOS version ?
Are these switches L2 , if they are the SVI is only for MGMT , if SVI is dropping could be an STP issue i causing it too , the switch has very little config , trunk port set to allow vlan 2 only and the rest of the ports are vlan 1 , even though vlan 1 is not really blocked on a trunk should still be permitted if access ports are working on vlan 1
This command canb show if there is constant L2 changes in the network which could cause interruptions to the SVIs ,if the timers are constantly resetting there is issues at layer 2
show spanning-tree detail | inc ieee|occurr|from|is exec
Hi Mark,
"Output of the command"
Switch.Test#
Switch.Test#show spanning-tree detail | inc ieee|occurr|from|is exec
VLAN0002 is executing the ieee compatible Spanning Tree protocol
Number of topology changes 4 last change occurred 04:37:12 ago
from FastEthernet0/1
Switch.Test#
Hi Mark,
-Different IOS versions because i have 48 ports to 24 ports switches.
-SVI is only for MGMT
-yes, L2 switches
-Vlan2 is only for the simulation...in my actual configs, there is no vlan2 except native vlan 1 in all switches.
Further; since these switches has been logged on cacti, no abrupt high cpu utilization found.
Hello
in addition to @Mark Malone  comments
@Mike202 wrote:
Description:
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
shutdown
interface Vlan2
ip address 172.16.16.2 255.255.255.0
no ip route-cache
ip default-gateway 172.16.16.1
VLAN Name Status Ports
1 default active Fa0/2, Fa0/3, Fa0/4, Fa0/5
Fa0/6, Fa0/7, Fa0/8, Fa0/9
Fa0/10, Fa0/11, Fa0/12, Fa0/13
Fa0/15, Fa0/16, Fa0/17, Fa0/18
Fa0/19, Fa0/20, Fa0/21, Fa0/22
Fa0/23, Fa0/24
2 test active Fa0/1, Fa0/14
interface FastEthernet0/1
switchport access vlan 2
switchport trunk native vlan 2
interface FastEthernet0/14
no ip address
Looks like you are running vlan 2 - Suggest you make sure all you switches interconnects have the correct trunk configuration and their specifying the native vlan as above
Also enable spanning-tree portfast and BPDU Guard on ALL access ports
description trunk port
switchport mode trunk  <--------
switchport trunk native vlan 2 <-----
interface x/x
description ACCESS Ports
switchport host
spanning-tree bpduguard enable
Kind Regards
Paul
Hi Paul,
After this incident started, i put all my switches in VTP mode Transparent. The Problem is once the SVI stopped, it can't be retrieved in any way except to reload the switch. That is the reason i took out 1 non-working SVI switch and configure int vlan 2 for the test purposes with another router. the attached config of switch.test has 1standalone router, 1 switch, 1 pc and still SVI has no response.
Mike202
Hello Experts,
Looking for a solution from your deep knowledge/experience!
As previously recommended by Paul/Mark. i have done all the steps and again 1 of my switch SVI stopped responding after 6 days in the network.
Attached details of config/output.
  • No STP topology changes observed
  • No BPDU messages observed
  • Nothing happened which i can see causes this switch to stop responding to other network devices.
Awaiting your suggestions.
BR,
Mike
