REPLACING MS390 WITH MS250
Sencyty
Hello guys am kind of new to Meraki, I need the best and most efficient way to replace MS390 Meraki switches in production with MS250.
there is feature differences in these models. migration total depends on the features you have already configured in MS390. if you configured MS390 with some features which not doable in MS250,you need to find the alternatives first. then you can claim new MS250 switch to dashboard and do configurations without moving MS390 from network. after everything confirmed, you can connect new switch and remove MS390. but gain, you need to make sure all required features are configured and alternatives applied for non supported features.
Good luck
KB
balaji.bandi
Its straight forward, since both from Meraki the confg should support as expected.
configure online as same as old MS390.
what challanges you see here ?
BB
Mark Elsen
  - You may also go here for that question : https://community.meraki.com/t5/Switching/bd-p/switching
 M.
