Replacing Supervisor engine for WS-C4507R+E standalone
niceeeeex
I recently upgraded WS-C4507R+E and the other supervisor engine did not boot up. I requested a replacement through cisco RMA and it will arrive tomorrow.
I just want to know if we need to configure anything on the new supervisor engine.
PS: this switch is a standalone switch.
Thank you for your answers.
5 Replies 5
balaji.bandi
Do you single sup card or dual sup card in the same chassis ?
below guide help to replace (Hope you have config backup to restore ?)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/hardware/configuration/notes/OL_29676.html
BB
It's dual sup card on same chassis.
niceeeeex
I was wondering if we still need to upgrade also the new sup engine even though the device is acting as Standalone.
if the Dual sup - then the IOS Code should be the same as Primary.
this Cat 6500, most of the steps same :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/91897-replace-frsm-cat65k.html
BB
marce1000
             - You may also verify module status-led in front of the box.
 M.
