Several Links Into Same interface without sub-interface
hfakoor222
on the CCNA workbook website
https://www.freeccnaworkbook.com/workbooks/ccna/configuring-basic-eigrp
the labs  show  sever serial 0/0 interfaces going into the same router (R 1 in this example)
Now when I'm on GNS 3 and trying to establish links between R1 and the rest of the routers I can only establish 1 link per s0/0 interface
In the tutorials the s0/0 int on R1 is not being sub-interfaced, regardless even if it were I wouldn't see if it would make a difference going out to 3 different routers
Is there something I am missing?
looks like the interfaces are simply not numbered correctly. Just use Serial0/0, 0/1, and 0/2.
7 Replies 7
balaji.bandi
as per the config looks like Frame relay, you need to configure frame relay (its been Long played with Router in GNS3)
worth look below video (Hope this make sense )
https://www.youtube.com/watch?v=9tTs35a5xNs
BB
I will check it out, any more suggestions?
I was thinking this also, that it is not labelled correct, his labs continue this throughout which makes it rather annoying
 but as i see the Lab, R1 has only 1 interface configured other Routers  are also in the same subnet, if you use a different interface in R1 ? will that subnet accept , it wont, since it over lap wth S0/0
BB
I tried configuring on different interfaces several times and the only solution that worked was to give it a separate address.
I think this site/tutorial was created for gns 1.3.3, which is as George Pauwen mentioned might involve different Dynamips images. I do know the tutorial has a preloaded topology that does not work with current version of GNS.
I am closing this post.
I think @balaji.bandi has a very good point, the IP addresses are overlapping...
I assume you are using the 'old' Dynamips images ? Which one to be exact ?
