RIP database showing auto-summary
Kevin Melton
Level 7
Level 7
I have a customer whom has a 3550 switch running IP routing.
The switch receives RIP updates from two edge routers. These routers are simply sending default routes to the switch.
For whatever reason, when I look at the switch and do a "sho ip rip database", it gives me the following output:
bhiedge#sho ip rip data
172.16.0.0/16 auto-summary
172.16.1.0/24 directly connected, Vlan3
This looks awkward to me, as hte only networks configured to RIP are the 172.16.1.0, not the 172.16.0.0, so I am not sure why is shows this on the switch.
thx
7 Replies 7
Edison Ortiz
If you are running RIPv2, auto-summary is turned on by default. You need to isse a no auto-summary command under the RIP process.
mahmoodmkl
Level 11
Level 11
in addition remember that RIP is a classful protocol.
Mahmood
I have checked that auto-summary entry's doesn't go even if you configure no auto-summary command.
Please rate if it helps.
thanks
You are correct.
I put a "no auto-summary under my global rip statement.
It still shows "auto-summary" when I perform a "sho ip rip data" command.
scottmac
Level 11
Level 11
Check to make sure that "Version 2" is also in your "router rip" configuration.
If "version 2 is there, you will also need "no auto-summary"
You can also go to each interface and define how you want RIP to operate (send version 2, receive version 1 .... )
Good Luck
Scott
Hi ScottMac
Thanks for your reply and great to have your post to this topic. I configured rip ver 2 and no auto-summary. I ckecked it again in router's it still shows that summary route in rip database.
Hope this could be an error or just RIP doesn't send summary route when we configure no auto-summary.
Need your input on it.
thanks
kamlesh
How have you entered the "Network" statements for each net/subnet?
Please post your 'Router RIP" section, and list the interfaces and addresses for "this" router, and the other routers it is connected to.
An out put from a "sh ip route" would be a good thing too.
Scott
