RIP
vincent.rs
Community Member
I have subnetted 192.168.0.0 with subnet mask 255.255.255.240. I am using RIP to advertise two networks 192.168.0.80/28 and 192.168.0.96/28 which are on the same router. When i try "show ip route" on the next connected router it is not receving the updated ip route table.
So i go back tho the previous router and check the config
Current configuration : 711 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname r5
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface Serial2/0
ip address 192.168.0.81 255.255.255.240
clock rate 56000
interface Serial3/0
ip address 192.168.0.97 255.255.255.240
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
router rip
version 2
network 192.168.0.0
ip classless
no cdp run
line con 0
line vty 0 4
login
end
Ther in RED. It is advertising 192.168.0.0. Why is it not recognizing the subnet even after it is version 2???
HI
First at all you should be sure that the networks that you are announcing in R5 are present in its rounting table. You can do this issuing the command "show ip route" and you should be able to see the two networks 192.168.0.80/28 and 192.168.0.96/28 directly connected. If you don't see one of the networks is because the port associated with the network is down, troubleshoot this problem first. If in fact you see both networks connected in R5's routing table, the next thing you should try is ping next hop  routers, if you can ping the next hop routers I'm sure you will be able to announce the directly connected networks to the surrounding routers.
One thing that you shuold kno about RIPv2 is that RIPv2 perfoms autosummary at the mayor network boundary.
vincent.rs
Community Member
Well this was being done in Cisco Packet Tracer!
cadet alain
Do no auto-summary
Regards.
Alain.
HI
Thanks a lot !!!! solved it!!!!!
