12-29-2006 10:33 AM - edited 03-05-2019 01:32 PM
Where do I find the ROMMON Software? I can't seem to find it in Software download section. It's for a 6509 w/Sup720 and MSFC3 card. I need c6ksup3-rm2.srec.8.4.2 specifically.
Thanks in advance
Chris
Solved! Go to Solution.
12-29-2006 11:26 AM
Chris,
Here's the link for the rommon software download page for 6500 switches.
http://www.cisco.com/cgi-bin/tablebuild.pl/cat6000-rommon
You can get there by accessing:
Software Center (downloads) --> LAN switching software --> LAN switches --> Catalyst 6500 series switches.
Sundar
12-29-2006 11:26 AM
Chris,
Sundar
