TCP Retransmissions
m.egan
I recently moved 12 users behind a new firewall and now during ms file transfers we get write delay errors. In doing some packet captures I can see TCP retransmits. What is the cause of this?
wochanda
Level 4
Level 4
Dropped packets.
dgahm
Level 8
Level 8
Matthew,
You could have a duplex mismatch. Check to be sure the NIC speed and duplex are locked down on both sides for the firewall interfaces.
Please rate helpful posts.
Dave
you were absolutely right. The switch ports were set for auto and setting themselves as 100/half. I forced them to match 100/full on the firewall and all is dandy. Thanks for the help. happy new year.
That is a very common problem.
Don't forget to use the pulldown to rate helpful posts.
Happy New Year!
