route-map for send ibgp route to ebgp neighbour if metrix
julxu
on asr1004, can I config to check a subnet metric if it is 30 (an example) than send the subnet to neighper with staticly set metrix to 35?
another way to say, can I do:
route-map to-neigher permit 5
   match metrix 30
   set metrix 35
Please ad
Julxu
Pawan Raut
Level 4
Level 4
Yes youcan do that but make sure if you want to send other subnet as it is then you have to add one more permit  line in route-map
match metric 30
set metric 35
route-map to-neigher permit 10
router bgp xxx
 nei xxxx route-map to-neigher out
Kindly rate for useful post
Pawan Raut
Level 4
Level 4
match metric 30
set metric 35
router bgp xxx
Hi Pawan
Great thanks for the advicd.
The permit 10 do not need anything else, some thing like match or set? please confirm.
Many Regards
Julxu
by default permit statement in route allow everything if we not set any condition like match
