Route outside Error Details inside
Lost & Found
Level 2
Level 2
I 1 Router(Act as Default Gateway 10.34.63.254) Connected to the Switch and 1 Router (ISP Router ) connected also in the switch and workstation.
From Workstation I can ping my ISP Router Inside and outside interface of the ISP router the problem is when i try to ping 8.8.8.8(Google) its not working.
from ISP router I can ping 8.8.8.8 and the next hop IP of the it address which is 121.54.54.17
From Gateway I can ping 121.54.54.18 only but not the next hop.
but when i use the firewall it can ping the 121.54.54.18 also the next hop which is .17
Router Default Gateway Config:
ip route 10.34.50.0 255.255.255.255 10.34.50.1
ISP Router
p nat inside source static 10.34.50.1 121.54.54.18
ip classless
ip route 0.0.0.0 0.0.0.0 121.54.54.18
ip route 10.34.50.0 255.255.255.0 10.34.63.254
ip route 121.54.54.18 255.255.255.255 10.34.63.254
Please see the attached phote.
thanks
The route on DG is wrong "ip route 10.34.50.0 255.255.255.255 10.34.50.1" is directly connected network no need for route. instead use
" ip route 0.0.0.0 0.0.0.0 10.34.50.1" on DG Router
