Router-in-a-stick inter-Vlan routing
omar.elmohri
I'm using a Cisco 1720 with 12.2(2) IOS
And the following command on the subinterface give an error:
encapsulation dot1q 1
Encapsulation command is available but with no parameters and it's not accepted alone.
Is there any way to so that?
Omar
6 Replies 6
mahmoodmkl
Level 7
Level 7
try with the native keyword and check.
Mahmood
Once I use '?' the encapsulation exists but:
encapsulation ?
gives me that the command is incorrect.
could you try upgrading from 12.2 to a newer IOS?
The only available RAM and Flash permitted me to go through 12.3(18)a
And the same problem I'm encountering.
Hi:
You need the IP PLUS image at least to set encapsulation protocols on a 1720.
Can this be the cause -
IEEE 802.1Q VLAN Routing - No on 1720 router -
http://www.cisco.com/en/US/prod/collateral/routers/ps221/ps223/prod_end-of-life_notice09186a0080147795.html
