Router On a Stick Troubleshooting
markringrose
I have configured a 2950 switch and a 1721 Router with 2 Windows 7 PCs in a Router on A Stick (ROAS) test.
The test that everything is working is if PC1 can ping PC2 and vice versa.
However, this does not work - the pings time out on both PCs.  However, from each PC I can ping both its own default gateway IP on the router and the default gateway IP of the other PC.  And from the Router I can ping each PC!
I really cannot figure out why this doesn't work - I set up an identical Packet Tracer test and it worked.
Apologies for the lengthy configuration below - maybe you can spot a problem?  Thank you in advance.
----SET-UP-----
PC1 -> Switch Fa0/1, VLAN 20, IP 192.168.20.3/24, Def G/W IP 192.168.20.1
PC2 -> Switch Fa9/1, VLAN 10, IP 192.168.10.3/24, Def G/W IP 192.168.10.1
Router -> Switch Fa1/5
Router has sub-interfaces set up for each VLAN with encapsulation dot1q
Switch has trunk port set to allow VLAN 10 and 20
---SWITCH AND ROUTER CONFIGURATION-----
This is the detail from Switch running-config for the ports in question  all other ports are inactive (its a 24-port switch)
interface FastEthernet0/1
switchport access vlan 20
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
switchport trunk allowed vlan 10,20
switchport mode trunk
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
switchport access vlan 10
This is the output from the Switch# sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/2, Fa0/4, Fa0/6, Fa0/7
                                                Fa0/8, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24
                                                Gi0/1, Gi0/2
10   VLAN0010                         active    Fa0/9
20   VLAN0020                         active    Fa0/1, Fa0/3
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Router# running-config
no ip address
speed auto
interface FastEthernet0.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
Router# sh ip route
R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C    192.168.10.0/24 is directly connected, FastEthernet0.10
C    192.168.20.0/24 is directly connected, FastEthernet0.20
7 Replies 7
glen.grant
To me it looks ok. You have to keep in mind that packettracer tends to be very buggy  .
Sandeep Choudhary
HI Mark,
Here is the my config:
Create sub-interfaces, set 802.1Q trunking protocol and ip address on each sub-interface
Router(config)#interface f0/0
Router(config-if)#no shutdown
(Note: The main interface f0/0 doesn’t need an IP address but it must be turned on)
Router(config)#interface f0/0.10
Router(config-subif)#encapsulation dot1q 10
Router(config-subif)#ip address 192.168.10.1 255.255.255.0
Router(config-subif)#interface f0/0.20
Router(config-subif)#encapsulation dot11 20
Router(config-subif)#ip address 192.168.20.1 255.255.255.0
(Note: In the “encapsulation dot1q 10″ command, 10 is the VLAN ID this interface operates in)
Configure VLAN
Switch(config)#vlan 10
Switch(config-vlan)#name SALES
Switch(config-vlan)#vlan 20
Switch(config-vlan)#name TECH
Set ports to access mode & assign ports to VLAN
Switch(config)#interface range fa0/1
Switch(config-if)#no shutdown
Switch(config-if)# switchport mode access
Switch(config-if)# switchport access vlan 15
Switch(config-if)#interface range fa0/3
Switch(config-if)#switchport mode access
Switch(config-if)# switchport access vlan 20
Switch(config-if)#interface range fa0/5
Switch(config-if)#switchport mode trunk
1. Please check all your port are up.
2. Check the config once again.
3. Make sure the swicth and router connection port configured as trunk and it should be up.
This config is working for me,
Dont forget to rate helpful posts.
mahmoodmkl
Level 7
Level 7
Can u add spanning-tree portfast under the switch ports where the pc are connected
Sent from Cisco Technical Support Android App
Drew Browning
Try this on the switch uplink interface
Switch(config)#interface  fa0/5
Switch(config-if)#switchport trunk encapsulation dot1q
cadet alain
If you have tested many times it is not spanning-tree anymore because it should be in forwarding state now but configuring Portfast should be done anyway so that if you disconnect/reconnect a host you don't have to wait for the port to go into forwarding state anymore.
You should disable software firewall on both PCs and test again.
As long as you can ping the other vlan IP on the router from a machine in a specific vlan it means that inter vlan is working and that your machines have got the correct default gateways.
Regards.
Alain
Had the same problem and Alain saved me. It was the firewall. Thanks
I have the same problem and I am using 3750 SW. Can the problem be with the 3750?
Why the firewall can be an issue?can you explain?
