Router on stick
saurabhkr
I was trying to configure routeron stick.
1) I configured sub interfaces on Router and assign  IP address
1) I configured switch 1 as VTP server and made 3 uplink ports as Trunk , also created 4 Vlans
Problem : Vlans are showing on Switch 1 only not on Switch 2,3 and 4
while those are configured as Clients.
So, please help me where I am missing
Configuration are as below
Router
Router#   sh ip int brief
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0        unassigned      YES unset  up                    up
FastEthernet0/0.1      192.168.1.1     YES manual up                    up
FastEthernet0/0.2      192.168.2.1     YES manual up                    up
FastEthernet0/0.3      192.168.3.1     YES manual up                    up
FastEthernet0/0.4      192.168.4.1     YES manual up                    up
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
description DATA
encapsulation dot1Q 100
interface FastEthernet0/0.2
description WIRELESS
encapsulation dot1Q 200
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.3
description VOICE
encapsulation dot1Q 300
ip address 192.168.3.1 255.255.255.0
interface FastEthernet0/0.4
description CLIENTS
encapsulation dot1Q 400
ip address 192.168.4.1 255.255.255.0
Switch#1
Vlan1                  10.10.20.1      YES manual up                    up
Vlan100                192.168.1.2     YES manual up                    up
Vlan200                192.168.2.2     YES manual up                    up
Vlan300                192.168.3.2     YES manual up                    up
Vlan400                192.168.4.2     YES manual up                    up
Switch_1:core#sh int trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa0/2       on           802.1q         trunking      1
Fa0/3       on           802.1q         trunking      1
Fa0/4       on           802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/2       1-1005
Fa0/3       1-1005
Fa0/4       1-1005
Port        Vlans allowed and active in management domain
Fa0/2       1,100,200,300,400
Fa0/3       1,100,200,300,400
Fa0/4       1,100,200,300,400
Port        Vlans in spanning tree forwarding state and not pruned
Switch_1:core#
Switch_1:core#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/5, Fa0/6, Fa0/7
                                                Fa0/8, Fa0/9, Fa0/10, Fa0/11
                                                Fa0/12, Fa0/13, Fa0/14, Fa0/15
                                                Fa0/16, Fa0/17, Fa0/18, Fa0/19
                                                Fa0/20, Fa0/21, Fa0/22, Fa0/23
                                                Fa0/24, Gig0/1, Gig0/2
100  Data                             active
200  Wireless                         active
300  Voice                            active
400  Clients                          active
Switch_1:core# sh vtp status
VTP Version                     : 2
Configuration Revision          : 0
Maximum VLANs supported locally : 255
Number of existing VLANs        : 9
VTP Operating Mode              : Server
VTP Domain Name                 : Cisco
Switch:2#sh vlan
1    default                          active    Fa0/11, Fa0/16, Fa0/17, Fa0/23
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
Switch:2#  sh int trunk
Fa0/1       on           802.1q         trunking      1
Switch:2#sh vtp status
VTP Version                     : 2
Number of existing VLANs        : 5
VTP Operating Mode              : Client
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
2 Accepted Solutions
Diana Karolina Rojas
Do all the switches have the same VTP domain, password and version? the others switches are in Client mode? the best practices are putting all switches in "transparent mode" for security reasons, but you can propagate the vlans first and after disable VTP and begin to configure the vlans device by device, or you can leave this enabled to do the vlans configurations in a easy way, is your desicion.
Please do not forget to rate useful post.
Best Regards,
your Switch 2 is in VTP transparent mode, it needs to be in client mode:
vtp mode client
9 Replies 9
first of all, you don't need IP addresses for the VLANs on switch 1.
Post the full configurations of both Switch 1 and Switch 2...
Hello Georg,
This the configuration
current configuration : 1510 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch_1:core
spanning-tree mode pvst
interface FastEthernet0/1
interface FastEthernet0/2
 switchport mode trunk
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
Switch_1:core#
Switch_1:core#
Switch 2
Current configuration : 2018 bytes
version 12.2
hostname Switch:2
 switchport access vlan 100
 switchport mode access
 switchport access vlan 200
interface FastEthernet0/9
Switch:2#
Switch 1's revision number is 0, which is not greater than the other switches. Try to add a vlan on switch 1 and then remove it. This should increase the revision number and force the vlan database to be shared out.
Best Regards,
Hello Diana Rojas and dbeattie
First of all Thanks for giving our time and helping me.
I made some changes like add vlan and delete , increase revision number . change VTP to transparent but still Vlans are not populating on downlink switches.
Here again i am posting outputs . Please have a look and help me
ROUTER
 no ip address
 duplex auto
 speed auto
 description DATA
 ip address 192.168.2.1 255.255.255.128
 description VOICE
 ip address 192.168.3.1 255.255.255.192
 description CLIENTS
 ip address 192.168.4.1 255.255.255.224
FastEthernet1/0        unassigned      YES unset  administratively down down
Serial2/0
Switch 1 = core switch
Switch_1:core#
100  Data                             active
200  Wireless                         active
300  Voice                            active
400  Clients                          active
Switch_1:core#sh vtp status
VTP Version                     : 2
Configuration Revision          : 5
VTP Domain Name                 : XYZ
MD5 digest                      : 0xE0 0x55 0x7D 0xD2 0xA1 0x9D 0x5A 0x67
Configuration last modified by 10.10.20.1 at 3-1-93 00:34:55
Local updater ID is 10.10.20.1 on interface Vl1 (lowest numbered VLAN interface found)
Switch_1:core#
Switch_1:core#
Switch2 = Host name Switch 2
Vlan1                  10.10.30.1      YES manual up                    up
Switch:2#
Switch:2#sh vlan
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Switch:2#  sh vtp status
VTP Version                     : 2
VTP Operating Mode              : Transparent
MD5 digest                      : 0x2D 0x26 0x20 0xAA 0x25 0xA0 0x80 0x2B
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
Switch:2#
vtp mode client
Hello Georg
I make the change but still not working
VTP Version                     : 2
Switch:2#
Switch:2#sh vlan
Hello Everone,
Got the solution, password was not set on switch2.
Thanks Diana
