Router Required
puneet_kandwal
Level 2
Level 2
I am looking for a very basic port density based requirement which should provide the cheapest solution...My requirement is :
1. 3 x 10/100/1000 Gigabit Ethernet
2. 1 port of VWIC2-2MFT-G703...
Kindly let me know if EHWIC-1GE-SFP-CU can be taken in 1921 router to suffice the requirement as this comes out to be the cheapest solution.
I have reservations about EHWIC-1GE-SFP-CU as this can support upto 800Mbps of throughput.
Or do I need to go with 2911 which has 3 onboard 10/100/1000 ports...
Kindly help...
Puneet
Reza Sharifi
Hi Puneet,
I would go with 2911.  This way, you can use the 3 10/100/1000 onboard ports and have more room for feature expiation.
Thanks for your reply...
On the safer side, I would also like to go in for 2911 based solution, but this being a tender based requirement, I am required to look for a cheapest solution available.
Best Regards
Puneet
Leo Laohoo
Before I could even recommend what router you should use, can you please elaborate what you are trying to do?  What speed do you hope to achieve with your WAN?
This is a tender requirement, I do understand that for exact sizing of any solution, details of the traffic and application to be supported are required..
But given the basic specifications to be met i.e
I am looking for a cheapest solution that can suffice the TENDER requirment...
Any solution that I propose will come with a disclaimer that for exact sizing application and traffic details are required"
Rgds
Puneet
