router transparent bridging carry multile LAN
yong khang NG
Level 5
Level 5
Hi All,
My question is it possible a switch carry multiple VLAN uplink to the router doing in bridging mode?
I not allow to have interface BVI with ip address? Is it the right answer for it is doing it in concurrent routing and bridging and integrated routing and bridging
Noel
Deepak Kumar
I didn't get your question. If you want to switch to Bridge mode then pass your same VLAN to uplink. It will in bridge mode.
If you want to know something other then please explain with your diagram with me.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi sir,
First of all thank you for the reply.
I found some mistake on my problem statement. Here's how it goes
say, vlan 100, vlan 101 and vlan 102 use a L2 switch uplink to a cisco router. But, i am no doing router on the stick, i just wan to do the router in bridging mode , uplink to a L3 device.
My concern is, can bridge mode carry multiple vlan?
thank you
Noel
Yes, it is possible.
Deepak Kumar
Deepak Kumar,
