Routing between 2 locations
health.net
I was assigned a task to connect two locations through a L2 VPN.
The infrastructure which i have are...
Fortigate 80 C firewall at Location A
CISCO 3560G at Location A
CISCO 3750G at Location B
2 MBPS Leased Line connecting two locations.
T1 line at Location A.
The requirements are as follows..
both locations should be in the same ip range (ex 10.80.71.1/24)
Internet for Location B should be from Location A
both locations should talk to each other.
Hope am clear in presenting my question.
Your advise requested in resolving.
Thanks in advance.
Bain
6 Replies 6
health.net
Experts,
Need your help
Hi Milan,
Thanks for your reply and also, looking only the concept.
But bit confused about your reply.
If you can provide me the config file as per my requirement it will be great help for me.
Else a step by step is appreciable.
Milan Rai
Hey Vijay,
Are you asking for the whole config file or...just the concept...????
If that's with the concept.......
At first when you will be doing the VPN setting you need to create tunnel for both of the interface........and dont forget the
tunnel ip will be on the same subnet......then...after that you need routing protocol that can be done with the OSPF....
announce both of the interface......From which A and B can be able to talk with each other.....
And regarding the Internet.....you need to route your internet traffic of location B to location A side.......which can be done on the firewall......
They are just my concept......
Hi Milan,
Attached is my requirement.
Please post your quiries in the attachment
Location A (3750G)
Vlan 80
Int Vlan 80
IP address 10.80.71.1 255.255.255.0
Int range gig 0/1 - 24
switchport access vlan 80
IP routing
ip route 0.0.0.0 0.0.0.0 (IP of Device that will alow them to use Internet)
Locattion B (3560G)
No IP routing
Vlan 80
IP address 10.80.71.5 255.255.255.0
Ip default-gateway 10.80.71.1
Int Range Gig 0/1-24
Swithport access vlan 80
Jawad
