Routing Issue on ASA please help
Vikrant Ambhore
Hello Friends,
I need Help For Configuring ASA, Please help, I think this is possible but verry complicated for me that's why I need guidence from you
Present Status
ISP Router (192.168.2.1)-------> Application Server(192.168.2.3)
There is Static NAT which is configured for 192.168.2.3 (Application Server),
Now I want to Attached ASA behind ISP Network But I can't Change Subnet of my Application Server but if need we can change Interface IP of ISP Router
ISP Router (192.168.4.1)-------> (192.168.4.101)ASA(192.168.2.1) ------------ Application Server(192.168.2.3)
My ISP router IP is 192.168.4.1 & it is plugged into fa0/0 of ASA & My Server is is pluged in ASA interface of 0/1 & want to Assagin Static NAT for Application Server, or Suggest any other way for this situation  Please help me You can refer my Attached Configuration
Now I am able to ping
Application Server--------192.168.2.1
Application Server--------192.168.4.101
ASA------>192.168.2.1
ASA------>192.168.4.1
R1------>192.168.4.101
R1------>192.168.2.1
But I am not able to ping
Application Server-------->R1
R1---------->Application Server
also I am unable to access Internet from Application Server
3 Accepted Solutions
vmilanov
The dynamic NAT, that is the nat-global commands pair, allows translation creation for flows originating from the higher security-level interface to lower ones only. If you need to allow connections, originating from a lower security-level interface, as it is your 'Outside', then you have to create a static translation:
- pull out an IP address from your global pool, or use a new one from the same subnet to NAT the server:
no global (Outside) 1 192.168.4.102-192.168.4.254 netmask 255.255.255.0
global (Outside) 1 192.168.4.103-192.168.4.254 netmask 255.255.255.0
static (inside,Outside) 192.168.4.102 192.168.2.3 netmask 255.255.255.255
Also, you will need to create at least an inbound access-list to permit interesting traffic in. Then, apply it to the 'Outside' interface:
access-list acl_outside_in extended permit ip any host 192.168.4.102
access-group acl_outside_in in interface Outside
And optionally, you can enable some ICMPs to ASA's interfaces and ICMP inspection:
icmp permit any echo Outside
icmp permit any echo-reply Outside
icmp permit any unreachable Outside
icmp permit any time-exceeded Outside
policy-map global_policy
class inspection_default
  inspect icmp
  inspect icmp error
end
HTH/Regards,
Vasil
Hi VIkrant,
So your Tulip router is directly connected to internet and ASA is connected to your Tulip Router. If this is correct then you no need to write static nat on the Tulip router as long as you have ASA and can do static nat on this ASA.
And what is 192.168.4.102, Vasil might be confused.
I think it is 192.168.4.101 (your applications server)
Please click on the correct answer if this answered your question.
Naidu.
   Please try this for testing.
ciscoasa(conf)#access-list inside_access_in extended permit ip 192.168.2.0 255.255.255.0 any
ciscoasa(conf)#access-list outside_access_in extended permit icmp host 192.168.4.1 any
ciscoasa(conf)#access-group outside_access_in in interface Outside
ciscoasa(conf)#access-group inside_access_in in interface inside
HTH,
Toshi
14 Replies 14
vmilanov
  inspect icmp
  inspect icmp error
end
HTH/Regards,
Vasil
Hi vmilanov,
Thanks for Your Reply
Is static nat  possible on Tulip Router for Application Server ?
because there is Static NAT configured on ISP router  for 192.168.2.3 (Application Server),
& Please help I have one query I am not sure why u did apply 192.168.4.102 ?
Please suggest
VIkrant
Hi VIkrant,
Naidu.
OK,
@Naidu
Thanks for Help,
Can you wrote configuration for ASA & my tulip Router, Because I am not getting you 100%
please look again
interface FastEthernet0/2
ip address A.A.A.248 255.255.255.0                                A.A.A.A  is my Static IP which is for Application Server
ip address 192.168.4.1 255.255.255.0 secondary
no ip directed-broadcast
ip nat inside
ip fast-switch enable
ip access-list extended internet
permit ip 192.168.4.0 255.255.255.0 any
ip nat pool int A.A.A.248 A.A.A.248 255.255.255.0
ip nat inside source static 192.168.2.3 X.X.X.249 ------------------------Static NAT
ip nat inside source list internet pool int overload
Because there is 3 Static IP on Tulip Router,
X.X.X.248    is for Internet for internal LAN user
X.X.X.249    is for Application Server
X.X.X.250    is configured on interface Tunnel987
Then how to define Static NAT on ASA please explain or just wrot config, I will understand this
Thanks Dear, I am happy
Hi Vikrant,
Here is the example how you can configure a static NAT on your ASA.
ASA(config)# access-list NET1 permit ip host 10.1.2.27 209.165.201.0 255.255.255.224
ASA(config)# static (inside,outside) 209.165.202.129 access-list NET1
Naidu.
Again got confusion I 'm sorry @Naidu
Is 209.165.202.129 my Static IP ?
10.1.2.27  = ?
209.165.201.0  =?
It would be great if you will wrote with IP conf ?
Realy sorry for desturb
Thanks in Advance
Vikrant
Hi Vikrant,
The below I just provided you the example.
You can replace the IP's with your real ones.
See the below reale config which i did in my ASA for static NAT.
static (inside,outside) 209.165.202.129 10.10.10.50 netmask 255.255.255.255
209.165.202.129: This can be your public IP which you have
10.10.10.50: This can be your Application server IP which will be nated to the above public IP and communicate outside world with that public IP.
Naidu.
I am Unable to Ping Tulip Interface (192.168.4.1) from Application Server also I am Unable to Browse Internet on Application Server, Please Help Me
Vikrant
You are changing your issue by each and every post.
Your first post is for configuring NAT on ASA.
Then you put Tulip router in loop.
Now you are saying that you are not able to ping Tulip from Application server.
This is very typical to understand and provide solution.
What is the actual setup?
Where is the tulip router connected?
Where is your ASA connected and what is the role?
Where is your Application server is connected?
Naidu.
Hi Naidu,
Please look on Attached Diagram
ASA 0/0--->192.168.4.101
ASA 0/2---->192.168.2.1
Application Server 192.168.2.7
Tulip
0/1---->192.168.3.1
0/2-----> 192.168.4.1
I want to ping 192.168.4.1   from 192.168.2.7 ( Application Server)
I think Now clear, Sorry for complicated
VIkrant:)
   Please post current configurations on Router(Tullip) and ASA.
Toshi
Hello thotsaphon,
Thanks for Responding,
Please Look on attached Config
I don't have Present Config of ASA, but I know I did changes only fromThis comment Please look vmilanov comment I did change only by his siggestion
Vikrant
HTH,
Toshi
Hi All,
Thanks for Help, I Did ASA in Transperent mode
Thanks for Giving time
