routing on vpn
carl_townshend
Hi all, I have configured my cisco router for remote access vpn, however, the pool I used is on the same subnet as the devices on the router, I can connect but cant ping any devices on the same subent that are connected to the router, is there any reason for this?
8 Replies 8
Tshi M
Level 5
Level 5
I will use a different subnet for the VPN users. It makes thing easier for administrative tasks such as ACL.
bmbreer
I'm sure there is a reason. Can you please post your config so we can properly troubleshoot.
Config here
Password:
TEST#sh run
Building configuration...
version 12.4
no service pad
hostname TEST
boot-start-marker
boot-end-marker
enable secret
aaa new-model
aaa authentication login default local
aaa authentication login userauthen local
aaa authentication enable default enable
aaa authentication ppp default local
aaa authentication ppp userauthen local
aaa authorization exec default none
aaa authorization network default none
aaa authorization network groupauthor local
aaa session-id common
dot11 syslog
ip cef
ip domain name TEST
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username TEST pasword xxxxxxx
crypto isakmp policy 1
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group UK_internal12
key TEST123456
dns X.X.X.X
wins X.X.X.X domain X.X.X.X
pool CT_POOL
crypto ipsec transform-set CT_TRANS esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set CT_TRANS
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 1 ipsec-isakmp
! Incomplete
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
archive
log config
hidekeys
ip ssh version 2
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
switchport access vlan 199
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
interface Vlan199
ip address 10.117.199.201 255.255.255.0
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname X.X.X.X
ppp chap password X.X.X.X
ppp pap sent-username X.X.X.X password x.x.x.x
5920999928639999
ip local pool CT_POOL 10.117.199.25 10.117.199.30
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 10.0.0.0 255.0.0.0 10.117.199.13
no ip http server
no ip http secure-server
ip access-list extended management
remark access list for ssh management
access-list 101 remark OUTSIDE_ALLOW_IPSEC
access-list 101 permit icmp any any
access-list 101 permit esp any any
access-list 101 permit udp any any eq isakmp
access-list 101 permit udp any any eq non500-isakmp
access-list 101 permit udp any any eq 443
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq 10000
access-list 101 deny ip any any log
dialer-list 1 protocol ip permit
snmp-server community public RO
snmp-server location CT
snmp-server contact CT
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password XXXX
transport input ssh
scheduler max-task-time 5000
ntp clock-period 17175028
ntp server 10.80.50.19
end
TEST#
This is what I would do:
1. Change the pool address to a different subnet.
2. Whatever 10.117.119.13 is, add a static route to the new pool address.
So an example:
TEST#ip local pool CT_POOL 192.168.1.20 192.168.1.50
device(10.117.199.13)#ip route 192.168.1.0 255.255.255.0 10.117.199.201
ChaosInMind
Can a VPN Client connect to a remote network correctly if they are on the same subnet? I thought they had to be different?
that is exactly what I suggested yesterday. He should try to use a different subnet for the vpn clients. it makes things easier.
That is what I thought, does it not have something to do with the encapsulation of the packet?
How would the devices on the same data link of the router know where the remote device is ? From what I can see, it's not on the same data link now. With proper routing (between the Pool IPs and the rest) you should be able to achieve reachability.
