Routing or NAT problem?
williamreed
I've got a network behind a cisco 2811 running the config below...Note: The Fast/Ethernet0/1 is now my external connection and serial is disabled.
I can connect to the internet, and the internet can see me, but I am unable to see my external ips from the internet. I recently had an ip change from t1 to fiber, and that's why I've disabled the serial and I'm using the fasteth01. Do you think there is just a simple routing issue I haven't accomodated for, or do you think there is a remnant somewhere deep in the config I am not seeing?
Thanks in advance!
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service sequence-numbers
ip subnet-zero
no ip source-route
ip tcp synwait-time 10
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool default
import all
network 10.10.10.0 255.255.255.0
dns-server 209.244.0.3 209.244.0.4
default-router 10.10.10.1
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$$ES_LAN$$FW_INSIDE$$ETH-LAN$
ip address 10.10.10.1 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description $FW_OUTSIDE$$ETH-LAN$
ip address 64.100.200.174 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex full
speed 100
no mop enabled
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 permanent
ip route 10.10.10.0 255.255.255.0 FastEthernet0/0 permanent
ip http server
ip http access-class 3
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat pool DynamicIPPool 64.100.200.97 64.100.200.102 netmask 255.255.255.224
ip nat inside source list 1 pool DynamicIPPool overload
ip nat inside source static tcp 10.10.10.129 80 64.100.200.103 80 extendable
logging trap debugging
access-list 1 remark INSIDE_IF=FastEthernet0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 3 remark Auto generated by SDM Management Access feature
access-list 3 remark SDM_ACL Category=1
access-list 3 permit 10.10.10.0 0.0.0.255
access-list 100 remark Auto generated by SDM Management Access feature
access-list 100 remark SDM_ACL Category=1
access-list 100 permit tcp 10.10.10.0 0.0.0.255 host 10.10.10.1 eq telnet
access-list 100 permit tcp 10.10.10.0 0.0.0.255 host 10.10.10.1 eq 22
access-list 100 permit tcp 10.10.10.0 0.0.0.255 host 10.10.10.1 eq www
access-list 100 permit tcp 10.10.10.0 0.0.0.255 host 10.10.10.1 eq cmd
access-list 100 deny tcp any host 10.10.10.1 eq telnet
access-list 100 deny tcp any host 10.10.10.1 eq 22
access-list 100 deny tcp any host 10.10.10.1 eq www
access-list 100 deny tcp any host 10.10.10.1 eq 443
access-list 100 deny tcp any host 10.10.10.1 eq cmd
access-list 100 deny udp any host 10.10.10.1 eq snmp
access-list 100 permit ip any any
access-list 101 remark Auto generated by SDM Management Access feature
access-list 101 remark SDM_ACL Category=1
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
access-list 102 remark Auto generated by SDM Management Access feature
access-list 102 remark SDM_ACL Category=1
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
no cdp run
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
access-class 101 in
privilege level 15
login local
transport input telnet
line vty 5 15
access-class 102 in
privilege level 15
login local
scheduler allocate 20000 1000
Will,
Usually encapsulation failed means no reply to the ARP request. Try changing your default route to point to the next hop address. Currently you are depending on the ISP router to proxy ARP which it is apparently not doing for the 64.100.200.103.
ip route 0.0.0.0 0.0.0.0 64.100.200.173
Dave
10 Replies 10
dgahm
Level 8
Level 8
Try enabling IP proxy-arp on your outside interface. If the ISP has a static route for the 64.100.200.103 that uses the interface (like your routes) instead of the next hop router address you need the router to proxy arp since the NAT global address is not within the subnet on your outside interface.
If that doesn't work have your ISP doublecheck the static route back to you.
Please rate helpful posts.
Unfortunately enabling the IP proxy-arp didn't work. Any other thoughts?
Will
William,
You need to know if the 64.100.200.103 packets are getting to your router.
First build an access list to use with debugging:
access-list 10 permit host 64.100.200.103
access-list 10 permit host X.X.X.X
The 2nd address will be the public address you are testing from.
term mon
debug ip packet 10
If you see the packets coming in then:
debug ip nat 10
Let me know what happens.
Dave
Dave,
I know the packets are getting to my router, as I am able to access the site from anywhere outside of my network.
When I try to get to the site 64.100.200.103 from inside my network though, I cannot get to it.
Will
I had once faced similar problem.That came out to be routing issue from the ISP end.They had removed the routes for my pool of live IPs and I was not able to access my VoIP devices from internet.My internet through NAT was working fine.
Once they had defined the routes, everything was normal.
I think this is the same prob. is in your case.Try talking this with ur ISP.
Hope that helps
JD
Will,
But the difference is that the packets are coming from your NAT pool addresses. The ISP may be blocking this from going back to the 64.100.200.103.
How about the debug NAT?
This will tell you what NAT is trying to do with those packets -- if they are getting to you.
Dave
rajinikanth
Level 3
Level 3
Your statements
and
your using dynamic natting for 10.10.10.0 network using ur DynamicIPPool range. which is specified by ur access list 1
Then ur using the same network ip for static translation
May be ur dynamic nat has overtaken ur static nat statements.
Try to deny the 10.10.10.129 host in access list 1
Hope this helps you,
Raj
Below are the results of the debug output for NAT.
Will
116767: *Dec 26 12:48:21.140 PCTime: NAT: s=10.10.10.2->64.100.200.97, d=64.100.
200.103 [932]
116768: *Dec 26 12:48:21.140 PCTime: IP: s=64.100.200.97 (FastEthernet0/0), d=64
.100.200.103 (FastEthernet0/1), g=64.100.200.103, len 48, forward
116769: *Dec 26 12:48:21.140 PCTime: IP: s=64.100.200.97 (FastEthernet0/0), d=64
.100.200.103 (FastEthernet0/1), len 48, encapsulation failed
Will,
Dave
Thanks Dave, that was it! Appreciate the help!
